Activity Forums Apple Final Cut Pro Legacy Final cut pro don’t want to open motion file
  • Final cut pro don’t want to open motion file
    Posted by Francisco Vazquez on September 21, 2010 at 3:07 am
    What to do when Final cut pro don’t want to open motion files. I have several project files with Motion clips. and the FCP crashes every time I try to open them. Can someone help?
    Rafael Amador replied 15 years, 11 months ago 3 Members · 7 Replies
  • 7 Replies
  • Rafael Amador
    September 21, 2010 at 5:00 am
    Hi Francisco,
    Export the stuff directly from Motion and bring it to FC.
    Cheers,
    rafael
    http://www.nagavideo.com
  • Ben Holmes
    September 21, 2010 at 10:57 am
    As keen as Apple are to suggest that you can drop Motion files directly onto a FCP timeline, in practice it is slow, unreliable and generally to be avoided. Render them out from Motion as ProRes 4444, the default now I think, and drop them straight onto your FCP timeline – if this is ProRes too, no rendering will be required.
    Avoid all .motn files in FCP wherever possible – it’s just another area where FCP needs a massive overhaul.
    Edit Out Ltd
    FCP Editor/Trainer/System Consultant
    EVS/VT Supervisor for live broadcast
    RED camera transfer/post
    Independent Director/Producer
    https://www.blackmagic-design.com/casestudies/detail.asp?case=therydercup
  • Francisco Vazquez
    September 21, 2010 at 10:40 pm
    Hello Rafael: Nothing works. FCP doesn’t want to open any Motion files. Not even new ones. At this point, will you recommend to uninstall and install the suite again?
  • Francisco Vazquez
    September 21, 2010 at 10:41 pm
    Hello Ben: Nothing works. FCP doesn’t want to open any Motion files. Not even new ones. At this point, will you recommend to uninstall and install the suite again?
  • Rafael Amador
    September 22, 2010 at 1:14 am
    No Francisco. Don’t break your head and fallow Ben advice.
    Export a self-contained movie frm Motion and import to FC.
    The round trip FC-Motion-FC never had worked properly.
    rafael
  • Francisco Vazquez
    September 22, 2010 at 8:44 pm
    Does that mean that I have lost the FCP projects that have been working for the last four weeks?
  • Rafael Amador
    September 23, 2010 at 1:03 am
    Why should mean that?
    You take the file from Motion and you import to the FCP projects where you have been working for the last four weeks.
    rafael
