Activity › Forums › Apple Final Cut Pro Legacy › final cut pro capturing problems/audio and video sample rate
  • final cut pro capturing problems/audio and video sample rate
    Posted by Studioska on April 26, 2006 at 12:40 am
    I need help with the settings in final cut pro. I just installed it on my new laptop and everytime I capture with my sonyvx2100 it reads that the audio and sample rate of one or more of your captured media files does not match the sample rate on you source tape. This may cause your video and audio to be out of sync. Make sure the audio sample rate of your capture preset matches the sample rate of your tape. So i changed it to 32 rather than the default 48. Then it started capturing which is great. But now at the end of the capturing, it reads before finishing, analyzing audio data. Is there anything I have to do to get this capturing footage to work. I am very frustrated. Any help would be great.
    Matthew Brunn replied 20 years, 5 months ago 2 Members · 1 Reply
  • Matthew Brunn
    April 26, 2006 at 5:36 am
    Go to Final Cut Pro>Easy Setup>DV NTSC. That should solve your setup issues.
    Hope this helps-
    Matthew
    Quad 2.5 G5
    OSX 10.4.X
    Ram 4GB
    FCP 5.1/AE 6.5/DVDSP4
