Activity Forums Apple Final Cut Pro Legacy Final Cut Pro Audio off 20 frames after capture
  • Final Cut Pro Audio off 20 frames after capture
    Posted by Kristin Ten broeck on September 22, 2009 at 1:16 am
    Hi, I am having a problem capturing my audio in my video clips in FCP 6.0.5.
    I am recording my video on a DVX 100B at 24p advanced. I checked my camera, and the audio record settings are set to 48kHz. I am using a capture preset at 48kHz, but every time I try to capture a clip the audio is 20 frames off.
    My capture presets are: DV NTSC 48kHz Advanced with Pulldown removal.
    Please does anyone have any idea what is happening here? When I check a QT in the capture folder is says the fps is at 23.98 and I have two mono channels of audio.
    Please help, I’m on a very tight deadline. Thank you very much for reading.
    Kristin
    Kristin Ten broeck replied 16 years, 11 months ago 2 Members · 2 Replies
  • John Fishback
    September 22, 2009 at 9:49 pm
    Check Final Cut Pro Menu > System Settings > Playback Tab to see if an offset is entered.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 2 (FCP 6.0.5, Comp 3.0.5, DVDSP 4.2.1, Color 1.0.3)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • Kristin Ten broeck
    September 23, 2009 at 6:55 pm
    I don’t know what happened because I tried changing my capture presets twice to capture advanced 24p with the 3:2 cadence. The first time it didn’t work, but then it started working.. I think this problem may have started when I started using the advanced 24p setting, but I can’t remember. It remains somewhat of a mystery to me, but it’s working now. Thank you.
