Activity Forums Apple Final Cut Pro Legacy Final Cut Pro Audio issue :S
  • Final Cut Pro Audio issue :S
    Posted by Davey Smith on March 19, 2009 at 1:53 pm
    Basically, I am editing a montage for a music film, and I lay down the audio track 1st which is an mp3 and I begin cutting the footage to that, but when i stop and play the audio track from the begining it is not playing the track normally, it is playing it then the track suddenly cuts to another portion of the song as if i have sliced the track and joined two completely different parts of the track together. The track which I layed down has not been edited in any way its literally been dragged and dropped onto the timeline from finder and it plays back smoothly when I play the mp3 in itunes, but for some reason FCP keeps making the track jolt so now my montage doesnt make sense rhythmically!
    Anyone know what the problem could be?
    Thanks guys
    Rafael Amador replied 17 years, 6 months ago 3 Members · 2 Replies
  • Joe Haughey
    March 19, 2009 at 2:32 pm
    Even though FCP accepts mp3’s you should make a habit of converting them to aiff’s or wav’s. Open your mp3 in quicktime and go file – export – and set the preset to ‘sound to aiff; or wav
    Joe Haughey
    https://www.editmule.com
  • Rafael Amador
    March 19, 2009 at 2:34 pm
    Export the track as .aiff
    Avoid headaches.
    rafael
    http://www.nagavideo.com
    (and here some clips for the friends: https://www.vimeo.com/2694745 )
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
