Activity Forums Apple Final Cut Pro Legacy Final Cut Pro Apects
  • Final Cut Pro Apects
    Posted by Jaco Rossouw on May 10, 2010 at 12:45 pm
    Hi Guys
    I have a sequence setup as follows:
    Frame 720 x 576 (ccir 601/dv pal (5:4) )
    Pixel aspect: pal – ccir 601 (720 x 576)
    When i export a tiff sequence and import it back into fcp the following happens.
    the screen size changes to 768×576 and aspect is listed as square in the properties.
    when i pull it down to the timeline fcp fixes it by distorting the aspect ratio to: 6.67
    my concern is that if i send the tiff sequence to grade or telestream that the clip is going to be displayed wrong.
    any insight would be greatly appreciated.
    thanks
    Jaco Rossouw replied 16 years, 3 months ago 1 Member · 1 Reply
