Activity Forums Apple Final Cut Pro Legacy Final Cut Pro and XD CAM File Transfer Issue
  • Final Cut Pro and XD CAM File Transfer Issue
    Posted by Harry Cook on August 2, 2007 at 12:52 pm
    Hi
    Much help required. I have just purchased XDCAM HD 350. I have downloaded and installed XDCAM Transfer v 1.0 software. When I open FCP 6 and attempt to import XDCAM HD footage the XDCAM software starts but throws up the error,”Cannot PARSE METADATA.xml”
    This same error was thrown up with the XDCAM Transfer v1.1 also.
    Any thoughts?
    Mark Maness replied 19 years, 1 month ago 2 Members · 1 Reply
  • Mark Maness
    August 2, 2007 at 1:31 pm
    Well, you can only use the Sony Transfer software version 1.1. 1.0 has lots of problems such as the on you have seen.
    I would suggest that you reinstall the 1.1 version of the software, restart you system and zap your PRAM. Make sure that your XDCAM HD is not connected when you update the software.
    ALSO…. You need to make sure that your XDCAM HD machine has the latest software installed in it. This gave me a fit at first. You’ll have to check the manual on how to check your software version. It escapes me at the moment.
    _______________________________
    Wayne Carey
    Schazam Productions
    http://www.schazamproductions.com
    https://blogs.creativecow.net/waynecarey
