Activity › Forums › Apple Final Cut Pro Legacy › Final cut pro 7/export files
Posted by Rodolfo Novaes on March 27, 2011 at 2:55 pmI have problem to export a project (feature film) from time line through Quick Time Movie to my deskt or to a HD. During the process the program (Final Cut Pro 7) stops and says: GENERAL ERRO. I have enough space in my hard drive and in my computer, actually it never happened before.
Thanks if someone can help me.
RodolfoRodolfo Novaes replied 15 years, 5 months ago 3 Members · 7 Replies -
Zane Barker
March 27, 2011 at 4:58 pmhow are you trying to export? You have not really given us any info to go off of other then you have a problem. More info please.
**Hindsight is always 1080p**
Rodolfo Novaes
March 27, 2011 at 10:52 pmHi there,
As I said I tried to Export ( File – Export – Quick Time Movie) a project using the Quick Time Movie and it starts well but after a couple of minutes the program ( final cut ) stops and says – General Error – and I can’t finish the exportation.
I used to export my projects in this same way and I never had problem.
Many thanks
Rodolfo -
Rodolfo Novaes
March 28, 2011 at 1:27 amI go to File and Export ( Quick Time Movie) and I don’t change anything there I just save.
Zane Barker
March 28, 2011 at 2:02 amTelling us you don’t change things does not tell ha what’s there.
Let’s start at the beginning.
What format video are you editing?
What are your timeline settings?
Is everything rendered before you try and export?
Are you exporting a self contained file or a reference file?
Are you exporting using timeline settings or IR other settings selected?
How full us the drive you are exporting the file to?
What format is that drive?With complete detailed info on your project and the export settings we might be able to figure out your issue.
Jeff Greenberg
March 28, 2011 at 11:25 amMy instinct is that you have some damaged media. Quick and easy test: duplicate the timeline twice.
On the first one, delete the 2nd half.
On the second one, delete the 1st half.Export both of those pieces. If one works and the other doesn’t? You know which half has the corrupt media.
Best,
Jeff G
Apple Master Trainer | Avid Cert. Instructor DS/MC | Adobe Cert. Instructor
You should follow me (filmgeek) on twitter. I promise to be nice.
Come See me speak at NAB!
Compressor Essentials from Lynda.com
(older but still good) Marquee, Media Composer (3.5) and Basic/Advanced Color DVDs (1.0) from Vasst.com
Contact me through my Website -
Rodolfo Novaes
March 28, 2011 at 11:53 amHi Jeff,
That’s a good idea! I’ll try that.
Rodolfo
