Activity Forums Apple Final Cut Pro Legacy Final Cut Pro 7.0.3 SD field issue
  • Final Cut Pro 7.0.3 SD field issue
    Posted by Joao Rodrigues on July 29, 2012 at 3:15 pm
    Hi Everybody,
    Does anyone could me help with the following issue.
    I’m shooting in about 5 different HDs codec but my end copy will be analog Betacam, a already tested a lot of different down conversions log and transfer to SD compressor to SD, BlackMagic realtime hardware downconversion it is the best result but I loose some resolution, all others downconversions the fields like dominance inverted. what workflow do you suggest to get best downconversion for Betacam SP?
    Joao Rodrigues replied 14 years, 1 month ago 4 Members · 4 Replies
  • Chris Tompkins
    July 29, 2012 at 6:51 pm
    SD is never gonna look as good.
    Your best bet I think, is to edit in HD and use the bmd card to feed the beta with a down convert.
    Chris Tompkins
    Video Atlanta LLC
  • Rafael Amador
    July 29, 2012 at 8:57 pm
    [Joao Rodrigues] ” all others downconversions the fields like dominance inverted.”
    I guess you are mastering in Prores.
    Remember that If you are in PAL land your master must be Upper first.
    Lower first for NTSC land.
    rafael
    http://www.nagavideo.com
  • Paul Jay
    July 30, 2012 at 10:28 am
    Edit in HD ProRes..
    Convert HD ProRes to SD ProRes in Compressor ( SET RESIZE FILTER TO BEST )
    Dump to Betacam from FCP
  • Joao Rodrigues
    July 30, 2012 at 10:53 pm
    Thank you guys! For your time!
