Activity Forums Apple Final Cut Pro Legacy Final Cut Pro 7 Shared Files Removed
  • Final Cut Pro 7 Shared Files Removed
    Posted by Michael Mayer on April 14, 2011 at 5:42 pm
    Hey I was trying to remove my FCP serial number to put in a new one using FCS Remover but accidentally removed all the shared files instead of just the registration. Now my FCP won’t open… I still have all the shared files in my trash bin but does anyone know how to get it working or where I might put the shared files so FCP can run again????
    Thank you so much
    Where we’re going… we don’t need roads.
    Michael Mayer replied 15 years, 5 months ago 2 Members · 5 Replies
  • Jon Chappell
    April 14, 2011 at 5:51 pm
    If you go to the Removed FCS Items folder in your trash, you can follow the file structure to see where the files were originally located.
    For instance, if a file was located at /Users/myname/Documents/myfile.txt, it would be located at Removed FCS Items/Users/myname/Documents/myfile.txt.
    My software:
    FCS Maintenance Pack – Tools to keep Final Cut Studio running smoothly and fix problems when they arise
    FCP Versioner – Backs up Final Cut Pro projects to XML and creates changelists for each revision
    More tools…
  • Michael Mayer
    April 14, 2011 at 6:07 pm
    I can only seem to see where the files are now… how do you see where they once were?? Thank you again
  • Michael Mayer
    April 14, 2011 at 6:11 pm
    I can only see where the files are now ie. /users/mike/desktop/removed fcs items/library. How do I see where they once where from this structure? Thank you again for your speedy response.
  • Jon Chappell
    April 14, 2011 at 6:16 pm
    Here’s a screenshot to show what I’m talking about. From looking at the file structure I can see that those files were originally located in /Library/QuickTime so all I need to do is drag them back there.
    But you may find it easier just to reinstall Final Cut Studio.
    My software:
    More tools…
  • Michael Mayer
    April 14, 2011 at 6:19 pm
    Thanks You!!!
