Activity Forums Apple Final Cut Pro Legacy Final Cut Pro 7 quit allowing to clip settings
  • Final Cut Pro 7 quit allowing to clip settings
    Posted by Daren Seifert on July 27, 2011 at 10:42 pm
    I already finished my first 11 minute film and all the editing went smoothy… mostly.
    But now I have to make a 2 minute preview of it and all the sudden when I select “in” or “out” to clip the sequence to the length I want, it doesn’t do anything. The arrows show like usual but the actual sequence stays the same.
    I even went to my first film and tried to edit it and it does the same thing
    Also when I double click the sequence it automatically goes to the viewer instead of the canvas… I really have no idea what to do.. and I can’t find anyone else with this problem
    I hope someone can help me, and thank you for your time
    Daren Seifert replied 15 years, 2 months ago 2 Members · 2 Replies
  • Jerry Hofmann
    July 28, 2011 at 8:14 pm
    Your post is unclear. You want to shorten a sequence I get, but the rest I don’t… when you select an in and out point what do you want to happen that isn’t happening? You do need to delete sections for any thing to happen, not just set points.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
  • Daren Seifert
    July 30, 2011 at 12:09 am
    Sorry for bothering you.
    For some reason if I don’t double click the sequence first it doesn’t clip right…
    Idk… but it’s working now
    thanks for the help
