Activity Forums Apple Final Cut Pro Legacy Final Cut Pro 7 exits when importing avchd folder
  • Final Cut Pro 7 exits when importing avchd folder
    Posted by Giovanni Gaglia on January 23, 2010 at 11:25 pm
    I’m beginning to use Final Cut Pro and I have to work with many sd cards avchd canon.
    I created on my hd several folders (data1,data2, etc) and I put the entire content of the sds on every folder.
    When I try to import the files in Final Cut I use the “log and transfer” option.
    I succeeded to do it with 7 out of 9 folders, without problems.
    With the remaining 2 I’m not able to import them and Final Cut exits immediately, maybe there’s something wrong with the directory structure, even if it is exactly the same as the other folders.
    How can I fix this?
    Is there any software capable of restoring possible structure problems?
    Is there any other way to bypass this error?
    Giovanni
    John Fishback
    replied 16 years, 8 months ago
    2 Members · 1 Reply
  • John Fishback
    January 24, 2010 at 3:31 am
    Some cameras have clip repair functions. See if your camera can do that. Also, you might checkout ClipWrap It’s an alternative to L&T. Maybe it’d have more luck with the problem media. Ther’s a trial version.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.1, Motion 4.0.1, Comp 3.5.1, DVDSP 4.2.2, Color 1.5.1)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
