Activity Forums Apple Final Cut Pro Legacy Final Cut Pro 6.0.1. upgrade? God help me….
  • Final Cut Pro 6.0.1. upgrade? God help me….
    Posted by Felexion Benito on January 21, 2008 at 1:00 am
    Greetings,
    I have been spending around 8 hours each day the past days in search of the 6.0.1. upgrade for Final Cut Pro. I am running version 6.0.
    The upgrade file (6.0.1.) is removed from the Apple site, only version 6.0.2. upgrade is available. But that upgade colides with my OSX. Im using 10.4.11
    Is there a kind soul out there that has the v6.0.1. upgrade file? I could pay you at least 100 quid for it through paypal as I am in desperate need of it.
    Yours faithfully,
    – Felexion
    Josh Hatter replied 18 years, 8 months ago 4 Members · 3 Replies
  • Michael Sacci
    January 21, 2008 at 1:15 am
    Email me at webstuff at michaelangelodv dot com
  • Phillip Van west
    January 21, 2008 at 2:04 am
    Exactly how does FCP 6.0.2 “collide” with OS 10.4.11? I’ve been using that combination since they were available with no problems. 6.0.2 has several bug fixes, too…
    pvw
    Phil Van West
    Terra Nova Productions
    Denver, CO
    Video Production/Post-Production
    G5 DP 2.5GHz / 4.5 GB RAM / OS 10.4.11 / FCP 6.0.2 / QT 7.3
  • Josh Hatter
    January 21, 2008 at 7:53 pm
    There are so many fixes in 6.0.2 that came up in 6.0.1 that i would encourage you to forget about 6.0.1 (might even be why they pulled it from the standalone downloads).
    We are running 25 edit suites with FCP 6.0.2 and OS X 10.4.11 with nary a hiccup.
    are you using the Software Update Utility? There’s a sequence of upgrades that have to happen before 6.0.2. Not in front of an edit suite but you need to install an Apple Pro Apps update, a security update, and i think Quicktime 7.3.1 in order to even see the 6.0.2 update in the Software Update Utility.
    As a general rule I would avoid updating with standalones so you can let the system keep track of your updates for you. If you dont have internet access from your edit suite but are running OS X server you could serve any updates from there.
    Hope this helps,
    Josh Hatter
    HDNet Engineering
