Activity Forums Apple Final Cut Pro Legacy final cut pro 5 does not import dv or Dvcam material from Sony HDV
  • final cut pro 5 does not import dv or Dvcam material from Sony HDV
    Posted by Dan Rosenfeld on December 4, 2006 at 6:33 pm
    HI THERE
    I AM WORKING WITH FINAL CUT PRO 5 ON A G4 POWERBOOK. I RECENTLY PURCHASED THE SONY HVR Z1E HDV CAMERA. EVERYTHING WORKS FINE WHEN WORKING IN HDV ( SO FAR IN 1080 50i) Now today for the first time i tryed to import DV SP material and the program won’t import it. I changed the project settings to DV Pal and also in the camera to DV out but the programm does not see the footage. It controlls the camera. so i tryed it again in HDV and was no problem. Later i tryed in DVcam, but that did not work either.
    Any ideas?
    Maybe because the footage was exported from Avid? Jealous Final Cut?
    shoot shoot shoot and don’t look back….
    roughrider
    David Smith replied 19 years, 9 months ago 2 Members · 1 Reply
  • David Smith
    December 5, 2006 at 4:36 am
    [roughrider] “Maybe because the footage was exported from Avid? Jealous Final Cut?”
    I would try recording some DV footage in the camera and then try importing to FCP. I’ve had no problem with DVCam material shot on a Z1u coming in to FCP 5.0 or 5.1x.
