Activity › Forums › Apple Final Cut Pro Legacy › Final cut pinwheels when I hit play
Posted by Ian Liuzzi-fedun on January 1, 2011 at 1:16 amI dont know what to do here. I was working in a Project and when I hit play fcp pinwheeled. I figured it was just that time to relaunch fcp so I did so and it happened again. Two hours later I have read everything on the net, trashed the prefs and any plug ins and I am still a no go. Please help. I have a dodecca with fcp 6
Ian Liuzzi-fedun replied 15 years, 9 months ago 4 Members · 10 Replies -
Tom Wolsky
January 1, 2011 at 1:27 amWhat are the specs for the media and the sequence?
All the best,
Tom
Class on Demand DVDs “Complete Training for FCP7,” “Basic Training for FCS” and “Final Cut Express Made Easy”
Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 4 Editing Workshop” -
Tom Wolsky
January 1, 2011 at 2:03 amTrash your prefs?
All the best,
Tom
Shane Ross
January 1, 2011 at 2:10 amWhat are the SEQUENCE SETTINGS? And then what is every format you have on that sequence? These are the details we need to know to help you.
For example…if you have DV, HDV, ProRes, H.264 footage, all on an HDV sequence…that’s pretty bad, and will lead to all sorts of issues. #1, non-GOP formats on a GOP sequence cause issues. #2, H.264 isn’t an editing codec. Stuff like that.
So we need to know ALL the details. Not “my arm hurts.” But, “My arm hurts near my elbow when I bend it like this…”
Shane
Read my blog, Little Frog in High Def -
John Pale
January 1, 2011 at 2:14 amYour media storage drive may be full , in need of maintenance or just going bad. Or not.
Ian Liuzzi-fedun
January 1, 2011 at 3:31 amI am sorry if I have not been specific enough. Here is what I believe you are looking for:
THe project where I first noticed this was a DVCPro HD native project with some HDV on the timeline. As i mentioned I have tried everything between DV and ProRes (DV, DV50, DVCPro HD, UNcomp 8 and 10 SD, Pro Res) in the appropriate native timeliness since this issue has begun and I have had no luck.
My arm appears to hurt when anything is done to it.
Ian Liuzzi-fedun
January 1, 2011 at 3:32 amMy media drive is indeed not full and all 5 of my raids and external hard drives are not going bad simultaneously.
Ian Liuzzi-fedun
January 2, 2011 at 6:31 pmSomehow after all of this the computer plays back perfectly today. Thanks for all your help anyway.
Ian Liuzzi-fedun
January 3, 2011 at 2:05 amI would appreciate it if you folks would check out:
https://forums.creativecow.net/readpost/8/1114769
