Final cut PC compatibility
Hello,
I’m an editor at a production company and although we are mostly on macs the director is PC based and we have a lot of problems when exporting projects from final cut to a quicktime and then trying to play them on PC.
I have tried several different export and compression settings however nothing seems to work properly and therefore I’ve ended up converting the .mov file to a .m4v through quicktime player, which isn’t an ideal workflow.Does anybody know of a export setting from Final cut that will be compatible on both PC and Mac without loosing any quality to the video?
Sarah
