Final Cut on an iBook?
Hi all,
Had a quick question about my new (used) iBook G4 (1.33 GHz Power PC/512 RAM/Panther 10.3.9).
I’m a video editor who uses Avid Media Composer at work, but I was hoping to get an older and cheaper version of Final Cut to mess around with, and get a feel for the program.
Are there versions of Final Cut that will run on an iBook? Final Cut Express?
Would I need to upgrade my OS? Add more RAM?
Like I said, I just want to use this for messing around. I would probably edit existing QTs, so I wouldn’t need to capture any footage.
Any advice? Thanks in advance
