Activity Forums Apple Final Cut Pro Legacy Final Cut is altering the source movs.
  • Final Cut is altering the source movs.
    Posted by Jason Murray on March 20, 2009 at 3:40 pm
    I have some footage I captured from an HVX200a camera using onLocation. They are DVCPRO HD quicktime files.
    They play fine in Quicktime when I open them at 1st. If I import them to a Final Cut Pro project, I get the warning “the following media files are not optimized….” I click OK and the mov works fine in FCP. Problem is, the source mov file has been changed! The .mov no longer displays a thumbnail or plays in Quicktime. Final Cut server no longer is able to recognize the codec (it could if I uploaded prior to opening in FCP).
    Any suggestions? I hope to be able to use my DVCPRO HD movs without having to transcode them. Is there a way to stop Final Cut Pro from altering the source .mov?
    Thanks for your time.
    Jason
    Rafael Amador replied 17 years, 6 months ago 2 Members · 1 Reply
  • Rafael Amador
    March 20, 2009 at 4:40 pm
    [Jason Murray] “The .mov no longer displays a thumbnail or plays in Quicktime”
    that sounds like a File Finder Info problem.
    Run DiskWarrior, TechTools or Drive Wizar.
    rafael
    http://www.nagavideo.com
    (and here some clips for the friends: https://www.vimeo.com/2694745 )
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
