Activity Forums Apple Final Cut Pro Legacy Final Cut File Migration/File Reconnection Question
  • Final Cut File Migration/File Reconnection Question
    Posted by Jeremy Jones on April 30, 2009 at 10:26 pm
    Howdy!
    I have a 2 hour film with over a thousand associated files I’m editing. Because he’s concerned about some erratic behavior the drive has been exhibiting lately, the director wants me to move all the files to a new terabyte drive.
    Here’s my question: First, is there an easier way than manually looking for every single file and then copying it over? Is there something within Final Cut that will allow me to tell it, “Copy all necessary files to ‘x’?”
    Second: I copied a large portion of the files over to a new drive already in one attempt, and thereafter tried to open the original Final Cut project file again. When I opened it, the files were, of course, offline. When I went to reconnect them, it wouldn’t let me tell it to just search the new drive for those files. When I click on “search” it just gives me the “I’m not gonna do that” sound. So is it impossible to have it autosearch the new drive for the offline media? Or will I have to manually reconnect everything now that it’s been moved?
    Michael Gissing replied 17 years, 4 months ago 2 Members · 1 Reply
  • Michael Gissing
    April 30, 2009 at 11:55 pm
    Software like Carbon Copy Cloner can be used to make a clone drive from your original. The other option would be to use Media Manager to copy the project to another drive. I suggest you read the manual on using Media Manager. It isn’t perfect and there have been many issues with it not dealing with speed changed clips and freeze frames.
    Unless you use Media Manager or make a cloned drive, FCP will require reconnecting which is a pain.
