Activity Forums Adobe After Effects Final Cut Express into After Effects
  • Final Cut Express into After Effects
    Posted by Dylan Lunde on February 1, 2011 at 6:07 am
    Hello, I have Final Cut Express 4 and Adobe After Effects CS5. I was wondering how I should go about adding the visual effects to the movies I edit within Final Cut. Should I create an entire sequence on FCE4, export it as a quicktime file, then put that onto AE? Or take the individual clips and add the VFX on AE first, then put it onto my FCE4 timeline? I am new to this and I’m not sure which is the best or easiest or quickest method. Thanks in advance.
    Dylan Lunde replied 15 years, 7 months ago 2 Members · 2 Replies
  • Angie Taylor
    February 1, 2011 at 1:24 pm
    Hi there,
    My recommendation is that you check out Automatic Duck. this is a third party solution that will allow you to open your FCP timeline in AE without any additional rendering. I use it all the time and it saves hours of extra work, amazing software!
    https://automaticduck.com/
    hope this helps!
    cheers,
    Angie
    Angie Taylor animation & illustration for television, film, web and devices
    https://www.angietaylor.co.uk
    Twitter: theangietaylor
    Linkedin: theangietaylor
    https://www.facebook.com/pages/Angie-Taylor/118378194869002
  • Dylan Lunde
    February 2, 2011 at 1:06 am
    Thank you for the reply. I’m not sure. I am extremely new and I do not know much at all. I know not having that information might make it harder for your suggestion and I apologize. If it’s too much, then don’t worry about it. Thanks much.
    Dylan Lunde
