Activity Forums Apple Final Cut Pro Legacy Final cut Express capture problems
  • Final cut Express capture problems
    Posted by Robert Liiv on December 10, 2007 at 10:17 pm
    I just purchased a new imac and had final cut express pre installed.
    I hooked up my panasonic 100a with my fire wire cable turned it on and then launched FCExp
    A window pops up and says it can’t recognize it. So I by pass it and go to settings and change the settings to ntsc basic that didn’t work either. So I prceeded to re set the FCExp to every and all the other settings and they don’t work either. What am I to do? Is there a problem with FCExp and the Panasonic 100a ?
    Dunwoody Lampton replied 18 years, 9 months ago 2 Members · 2 Replies
  • Dunwoody Lampton
    December 11, 2007 at 2:39 am
    “A window pops up and says it can’t recognize it.”
    “It” can’t recognize what?
    “So I prceeded to re set the FCExp to every and all the other settings and they don’t work either.”
    Don’t work for what? What were you trying to do by trying different settings?
    Not trying to be difficult, but there are a billion “its” and a ton of “whats” involved in configuring software and hardware. Be a bit more specific when describing your dilemma and then folks can more easily help you.
    If “it” is camera compatibility with FCE, then try first going to Apple’s website for the listing:
    https://discussions.apple.com/thread.jspa?threadID=829322&tstart=165
    Good luck.
  • Dunwoody Lampton
    Good luck.
