Activity › Forums › Apple Final Cut Pro Legacy › final cut express and Sony HD camera
  • final cut express and Sony HD camera
    Posted by Medusaette on June 12, 2006 at 4:23 pm
    I am student at the University of Lethbridge – I have just purchased a sony hdv 1080i/minidv – I have final cut express – I am able to capture, I have a power book and imac – but on both computers it drops frames – and does not play back in ‘real time’ – i have changed the settings, set up and prefrences for hd…any ideas or suggestions?
    Doug Buckser replied 20 years, 3 months ago 3 Members · 2 Replies
  • David Battistella
    June 12, 2006 at 6:03 pm
    I suggest that oucapture to an external drive FW 400 or 800, for starters. After you have captured, make sure just the drive is connected when you are editing.
    David
  • Doug Buckser
    June 16, 2006 at 6:06 am
    G’day,
    I’d consider doing any or all of the following.
    1. Increase the RAM to the maximum amount available
    2. Use a 7200-rpm or faster external hard disk as the capture location. It’s better to have separate disks for the operation system and the storage for the capture
    3. Shut down as many other applications as you can
    4. When you’re capturing, don’t use other applications
    Please let us know how you’re going.
    Regards,
    Doug
