Activity › Forums › Apple Final Cut Pro Legacy › Final Cut Export to Broadcast with MPEG-2 HD Multiplexed, PAL
  • Final Cut Export to Broadcast with MPEG-2 HD Multiplexed, PAL
    Posted by Máté Bögi on October 26, 2012 at 2:56 pm
    Dear All,
    Again, I need some assistance in exporting with these settings from Final Cut Pro. Or should I use compressor?:
    Format: MPEG-2 HD Multiplexed, PAL
    Frame rate: 25 fps
    Field order: None (progressive)
    Bitrate: 25 Mbps Constant bitrate (CBR)
    Color primaries: ITU-R Rec. 709
    Audio format: MPEG-1, Layer II Audio, Stereo 16 bit, 48 KHz, 384 kbps bitrate
    How can I export or compress my video to fit?
    My edit is in FULL HD (1920×1080), compressed from RED RAW 4K. fps is: 23.98
    Thank you!
    Kris Merkel replied 13 years, 11 months ago 3 Members · 4 Replies
  • Kris Merkel
    October 26, 2012 at 3:24 pm
    You should use compressor, as you will have more control to optimize the encode.
    “Think of everything in terms of building capacity.”
    Kris Merkel
    twitter: @kris_merkel
    Product Manager, Flanders Scientific Inc.
    http://www.shopfsi.com
    Co-Founder, Atlanta Cutters Post Production User Group
    http://www.atlantacutters.com
    2.2Ghz MBP core i7
    16Gb RAM
    CS 5.5
    FCP7 and Studio
    Blackmagic Design UltraStudio 3D
    AJA IO XT
    FSI LM-2340W
  • Máté Bögi
    October 26, 2012 at 3:26 pm
    I just don’t really get compressor. Which setting shall I use? and how can PAL still be
    1920×1080 in size?
  • Shane Ross
    October 26, 2012 at 3:37 pm
    PAL is mainly a frame rate…especially in HD. In SD it was frame rate and frame size different than NTSC. But now, HD unified frame size. PAL is 25fps. PAL HD is 1920×1080 25fps…or 1280×720 50fps. 1080i50 is PAL 25fps interlaced. 1080p25 is PAL 25fps progressive.
    Shane
    Little Frog Post
  • Kris Merkel
    October 26, 2012 at 3:43 pm
    NTSC and PAL do not really exist in HD video. Most folks refer to them this way because of the frame rate, but it is not correct for a spec to be HD and PAL. If you are unfamiliar with compressor I would start with the stock settings and encode a small portion of the most likely footage where you would see compression artifacts ie fast motion, hard lines ect. and then adjust the parameters until that section looks good.
    Compression and compressor are to big in scope to give you a tutorial in a forum post and to be honest every piece of video is unique and may require custom settings to optimize the encode. The stock settings in compressor are a good start. The is also a manual that comes with the software that will describe what each of the settings are.
    Start with the MPEG2 program stream and then customize the settings in the inspector tab. Make sure you save your settings.
    Kris Merkel
    2.2Ghz MBP core i7
    16Gb RAM
    CS 5.5
    FCP7 and Studio
    AJA IO XT
    FSI LM-2340W
