Activity Forums Apple Final Cut Pro Legacy Final Cut Error opening project “file format is too new for this version of the application.”
  • Final Cut Error opening project “file format is too new for this version of the application.”
    Posted by Kelly Laudien on August 4, 2010 at 6:37 pm
    I went through the media tool on my Final Cut Pro and consolidated sequences and Media to another drive. When my friend tries to open it she gets this error message “file format is too new for this version of the application.” We have the same exact version how can we get this to work. Is it a setting?
    Jeremy Garchow replied 16 years ago 4 Members · 8 Replies
  • 8 Replies
  • Alan Okey
    August 4, 2010 at 6:39 pm
    Ask your friend to run Software Update. Although you’re both using the same major version of FCP, there may be a point release that your friend hasn’t installed yet.
  • Kelly Laudien
    August 4, 2010 at 6:43 pm
    When you say software update you mean go to the apple icon and run software updates right? We currently both do this so I know we have the same updates. Is there anything else?
  • Jeremy Garchow
    August 4, 2010 at 7:19 pm
    Project Repair might fix this:
    https://www.digitalrebellion.com/fcs_maintenance.htm
    Do you both have the same OS?
  • Diana Costantino
    August 5, 2010 at 3:35 am
    We both have mac os 10.5.8.
  • Diana Costantino
    August 5, 2010 at 4:01 am
    I tried the repair kit and it says that there is nothing corrupt and that it is repaired i guess. I still can’t open the project nor can I open the version that I consolidated through media manager onto the drive.
  • Jeremy Garchow
    August 5, 2010 at 4:22 am
    Try making a new user and opening the project.
  • Kelly Laudien
    August 5, 2010 at 1:28 pm
    ok we just realized that I have 6.06.6 fc and Diana has 6.0.1 but heres the problem we both bought and loaded the same version 2 years ago and I did not buy a upgrade how did I get a newer version and can she get an upgrade for free?
  • Jeremy Garchow
    August 5, 2010 at 2:52 pm
    I think this has been addressed in this thread, but “Diana” needs to run software update from the Apple menu.
