Activity Forums Apple Final Cut Pro Legacy Final Cut Effects
  • Final Cut Effects
    Posted by Praveen Nu on October 28, 2011 at 4:20 am
    Hi All,
    I have created a Final Cut Effects in Motion and its working fine. My .moef file has a duration of 300 frames. If i apply it to a 600frame clip, its stretching and i want to avoid that. Either i can loop it twice or i can select first 300 frame and apply it to that selection only. Pls give me a solution to achieve this.One more thing is there a way to offset the effects in FCP?
    Thank you,
    Praveen N U
    Praveen Nu replied 14 years, 11 months ago 1 Member · 1 Reply
  • Praveen Nu
    October 28, 2011 at 11:18 am
    Offset means .. the clip has 600 frames duration and i want the effect to start after 100 frame. Is that possible with out splitting the layer by putting a marker or something?..
