Activity › Forums › Apple Final Cut Pro Legacy › Final cut… crash… ka-pow… NEED HELP :(
  • Final cut… crash… ka-pow… NEED HELP :(
    Posted by Mike Domenick on November 12, 2008 at 4:09 am
    I’ve done searches on this forum for this solution, but I can’t find a solution.
    I’m working on a project for the Style Network and all of us can’t wrap our heads around this problem. We have several editing bays where editors are working on certain acts (Editor 1 works on act 1, editor 2 works on act 2, ect). The editing bay with editor 1 keeps crashing. When bringing the project over to another editing station, the project still crashes. We have tried every solution but still cannot figure out the problem. We’ve done the simple restoring preferences, trashing render files to the complex of redigitizing all the footage and rebuilding the project from scratch. Still, it crashes. One thing I’ve noticed is that for some reason it says MPEG2CompressorCompanentDispatch despite the fact that all the footage was captured at XDCAM HD422 1080i60 (50 Mb/s) and the sequence is the same preference. Any help?
    Here is the crash log. I’ve included only the error and the thread. If any other info is needed, please let me know.
    Process: Final Cut Pro [325]
    Path: /Applications/Final Cut Pro.app/Contents/MacOS/Final Cut Pro
    Identifier: com.apple.FinalCutPro
    Version: 6.0.4 (6.0.4)
    Build Info: FCPApp-806171150~43
    Code Type: X86 (Native)
    Parent Process: launchd [134]
    Date/Time: 2008-11-11 18:49:07.698 -0800
    OS Version: Mac OS X 10.5.5 (9F33)
    Report Version: 6
    Exception Type: EXC_BAD_ACCESS (SIGBUS)
    Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000000
    Crashed Thread: 291
    Thread 291 Crashed:
    0 com.apple.AppleHDVCodec 0x0caef78e MPEG2CompressorComponentDispatch + 383076
    1 com.apple.AppleHDVCodec 0x0caca69f MPEG2CompressorComponentDispatch + 231285
    2 com.apple.AppleHDVCodec 0x0cac09d3 MPEG2CompressorComponentDispatch + 191145
    3 com.apple.AppleHDVCodec 0x0caa63a5 MPEG2CompressorComponentDispatch + 83067
    4 com.apple.AppleHDVCodec 0x0cac02f1 MPEG2CompressorComponentDispatch + 189383
    5 com.apple.AppleHDVCodec 0x0cac026d MPEG2CompressorComponentDispatch + 189251
    6 libSystem.B.dylib 0x961f36f5 _pthread_start + 321
    7 libSystem.B.dylib 0x961f35b2 thread_start + 34
    Thread 291 crashed with X86 Thread State (32-bit):
    eax: 0x00000000 ebx: 0xff906580 ecx: 0x00000780 edx: 0x00000001
    edi: 0xffffff8e esi: 0x00000780 ebp: 0xb34c61d8 esp: 0xb34c6190
    ss: 0x0000001f efl: 0x00010282 eip: 0x0caef78e cs: 0x00000017
    ds: 0x0000001f es: 0x0000001f fs: 0x0000001f gs: 0x00000037
    cr2: 0x00000000
    Michael John replied 17 years, 8 months ago 4 Members · 7 Replies
  • 7 Replies
  • Andy Mees
    November 12, 2008 at 7:07 am
    Mike
    XDCAM HD 422 is an MPEG format and its native codec, as supplied by Apple, is part of the AppleHDVCodec.component bundle.
    Andy
  • Mike Domenick
    November 12, 2008 at 8:09 am
    I found that out recently, but it still doesn’t explain why it’s crashing. Sometimes it happens during a render, sometimes it doesn’t. It crashes nearly every time I try to export.
  • Andy Mees
    November 12, 2008 at 12:31 pm
    Mike
    Can I reasonably assume that you are working with footage transfered from an F700 ? And that the “capture” is via XDCAM Transfer rewrapping the camera native MXF clips to MOV files for use in FCP? And the Export is also using XDCAM Transfer back to disc as MXF wrapped MPEG HD 422 or exporting as Quicktime Movie with or without transcode to other formats? Can you also confirm that your workflows work flawlessly with projects and content acquired and handled in any other suite other than your Edit 1? Just looking for some more details to try to figure out what’s up.
    Cheers
    Andy
  • Mike Domenick
    November 12, 2008 at 1:44 pm
    —Can I reasonably assume that you are working with footage transfered from an F700 ?
    Yes
    —And that the “capture” is via XDCAM Transfer rewrapping the camera native MXF clips to MOV files for use in FCP?
    Yes
    —And the Export is also using XDCAM Transfer back to disc as MXF wrapped MPEG HD 422 or exporting as Quicktime Movie with or without transcode to other formats?
    Quicktime
    —Can you also confirm that your workflows work flawlessly with projects and content acquired and handled in any other suite other than your Edit 1?
    The project, when brought into another editing bay (Edit 2-9), will also crash. We’ve also tried transferring the media and projects to another Raid (Thinking it may be the drives). Final Cut seems to crash when scrolling through the timeline or when rendering. However, other projects (other episodes of this show) seem to work fine in Edit 1.
  • Andy Mees
    November 12, 2008 at 2:27 pm
    Mike,
    As a workaround until the cause is nailed down, try changing your sequence codec to ProRes 422 (obviously the source remains the same native XDCAM HD 422) … now, does FCP still crash when scrubbing in the ProRes timeline, and when exporting a self-contained Quicktime Movie (w/Current Settings) from that ProRes 422 sequence, do you still get crashes?
    As an aside, if you create the project in Edit 2-9 eg not transfer it from Edit 1 but create it from scratch in Edit 2, do you get the same problem. Basically, can you confirm that the issue is wholly edit suite / fcp installation independent?
    Andy
  • Mark Maness
    November 12, 2008 at 3:25 pm
    One more thing to try, Mike…
    Trash your preferences, and try again. If it’s still happening, it maybe be a piece of corrupt media – maybe something that was imported or it could be a render file.
    You can clear out the render files using Render Manager and then re-rendering your program.
    But from what I gather from the posts, it sounds like a piece of corrupt media that was imported using Sony Software Transfer plugin. Its happened to me before.
    _______________________________
    Wayne Carey
    Schazam Productions
    https://web.mac.com/schazamproductions
    schazamproductions@mac.com
  • Michael John
    January 20, 2009 at 6:59 pm
    When ever I send a project from Final Cut to compressor.
    Final cut becomes unresponsive.
    Is this a ram problem? I am using a 2.33GHZ MacBook Pro with 2 gigs of Ram.
