Activity Forums Apple Final Cut Pro Legacy FINAL CUT consistantly files offline
  • FINAL CUT consistantly files offline
    Posted by Matt Goldschmidt on February 20, 2010 at 4:55 pm
    I freelance for a production house.
    I do all my edits, capture, etc on a traveler
    I get to the shop with my drive, copy all the media and material off the traveler to the shops raid.
    disconnect my traveler, open project, reconnect if needed.
    I leave.
    In house editor opens project… media offline.
    he reconnects
    saves
    re opens later…..
    media off line.
    all stored on RAID drive.
    Thoughts?
    btw, I cannot consolodate the project, reviews and changes are made after this.
    Then, I do fixes and deliver prj file for layoff.
    Matt Lyon replied 16 years, 7 months ago 2 Members · 1 Reply
  • Matt Lyon
    February 21, 2010 at 6:27 am
    Does the same thing happen if he copies your bins and timelines to a fresh project before relinking and saving?
    You should also check the path names that FCP is trying to look for when the media shows up as offline. You can do this in the relink media window or by exporting an XML and checking the ‘pathurl’ fields.
