Activity Forums Apple Final Cut Pro Legacy Final Cut capturing issues
  • Final Cut capturing issues
    Posted by Shane Pase on May 9, 2009 at 12:34 am
    Greetings, I am new to FCP6. I am trying to capture an 85 minute HD DVC tape from my Sony HC9 miniDV HD camera. I am able to get everything going and to start the log and capture. It captures about 15-20 minutes and then stops creating files/clips. It still shows that it is capturing, but it is only running the camera footage through the capturing viewer on FCP6. Any ideas what is causing this and what I can do to fix it? Thanks in advance.
    Kent Stipp replied 17 years, 4 months ago 2 Members · 1 Reply
  • Kent Stipp
    May 9, 2009 at 1:40 am
    the tapes are 63 minutes. so did you have it in LP? I have had issues with mini dv in lp mode
    Kent Stipp
    Life Begins at 155mph
    Ki PRO Lens to Post
    3am Studios llc.
    3amstudios.org
    Sharedsummitsfever.com
