Activity › Forums › Apple Final Cut Pro Legacy › Final Cut captures quit after one second
  • Final Cut captures quit after one second
    Posted by Mike Pell on April 24, 2009 at 7:21 pm
    Am capturing HDV from a JVC BR-HD50 deck via Firewire into Final Cut Pro 6 and every capture quits at exactly one second. They are manual captures. Project is set for 720P 30 and deck is set for the JVC which is NTSC Firewire as per FC website. There don’t seem to be any presets for limiting capture lengths in Final Cut unless I am missing something. Clues as to why this is happening? Thanks
    Samah Bennett replied 17 years, 5 months ago 4 Members · 3 Replies
  • Josh Olenslager
    April 24, 2009 at 9:40 pm
    I’ve seen this happen when there isn’t enough hard drive space for the capture destination. There is also a limiter in FCP under “system settings” on the “capture scratch” tab.
    Josh
    Digital Media, Thought Equity Motion
  • John Grilli
    April 24, 2009 at 10:41 pm
    Your hard drive is probably the culprit, not fast enough for 720P HD footage. Stay in the HDV codec.
  • Samah Bennett
    April 25, 2009 at 12:40 am
    Try changing the location of your capture scratch, see if that makes a difference. Try setting it in your documents area, and also on your desktop, see if that changes anything.
    Also, try throwing out your Final Cut Pro User Data.
    To find that, navigate from Home>Library>Preferences and then once in Preferences you should find it there. Just make sure you save any plug-ins before you throw out the folder.
