Activity Forums Apple Final Cut Pro Legacy Final Cut adding random frames? How do I correct?
  • Final Cut adding random frames? How do I correct?
    Posted by Oliver Tosh on February 15, 2011 at 5:51 am
    For some reason on this new project I am working on, Final Cut is acting up. I am using the latest version and I have opened the project oh two separate computers with the same problem showing up.
    The problem is I have one video layered on top of another. When the top video ends and the bottom video continues Final Cut will insert a random frame from earlier in the cut. If I look at the footage frame by frame there is no problem. It only happens when it is played back. I though that the final render might not have the problem since it does not show up frame by frame but sure enough, it renders out that way too.
    What can I try to correct this? I have tried deleting my render files and re-rendering but that does not fix it.
    Thanks for any help.
    Oliver Tosh replied 15 years, 7 months ago 2 Members · 2 Replies
  • Tony Brittan
    February 15, 2011 at 1:58 pm
    Are you using .mp4 / H.264 footage? That will cause that. If so, convert your footage to ProRes or another editable format first.
    Tony Brittan
    Owner – Island Shore Productions
  • Oliver Tosh
    February 16, 2011 at 2:43 am
    I got some advice that worked. If anybody else is having this problem this is what corrected it.
    Simply create a new sequence. Copy the entire edit from the old sequence and paste it into the new one and re-render.
