  • Posted by Jeremy Pellington on July 14, 2009 at 8:31 pm
    Hello,
    I am a beginner to final cut pro 6 and I own a canon hv20 camcorder which I plan to very soon shoot some footage… I know this may seem very general, but I have done some research and I really need some opinions. I need this footage to look as cinematic as possible when I am finished editing it. What settings should I shoot in? I am assuming the cine mode in HD? What would be the best bet to import my footage? I plan on putting the footage to disc and sending it to a couple of festivals. how should I go about compressing the footage? I have read too much about people running into problems down the road after they’ve shot and transferred their footage. I do not want to have to deal with that.
    Also, would I have to perform a 3:2 pulldown?
    Thank you very much for your help.
    -Jeremy
    Jeremy Pellington replied 17 years, 1 month ago 2 Members · 2 Replies
  • John Fishback
    July 14, 2009 at 9:55 pm
    I don’t know the camera, but I suggest the HD 24p setting if you’re going for a film look. The camera shoots HDV so you can capture in HDV, or if your computer and version of FCP supports ProRes, use that (checkout the Easy Setups for HDV). Many people like the ProRes codec for its editability (is that a word?), but others are fine with HDV native. Search the Cow any you’ll find a lot of discussion about this.
    Search this forum and the DVDSP forum for advice on how to use Compressor to encode and DVDSP to make your DVDs. You’ll get better, more specific advice if your questions are more specific.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • Jeremy Pellington
    July 15, 2009 at 2:48 am
    thank you very much John, I will look into ProRes and definitely search those forums. I have a lot to learn. any more comments would still be a nice help!
