Activity Forums Audio Final Cut 6.0 Editor wants some audio suggestions
  • Final Cut 6.0 Editor wants some audio suggestions
    Posted by James Dow on March 27, 2013 at 7:36 pm
    I’m wanting to improve the overall audio quality of my video productions. My typical project gets played back to a high school gymnasium full of senior citizens, via Playback Pro, feeding a fairly low quality PA system. Main audio is usually lav mic from an interview, with music mixed under. My levels are usually consistent, but I need some tips about audio filters or effects that I should be using to give the soundtrack that extra presence. I have Apple Soundtrack, in addition to the standard Final Cut audio filters. Suggestions??
    James
    JPD
    Peter Groom replied 13 years, 6 months ago 3 Members · 2 Replies
  • Noah Kadner
    March 27, 2013 at 10:31 pm
    can you give a better example? Generally speaking- the best advice for improving your final audio is improving your recordings. Can you get better mics, closer micing, better acoustic settings, etc.
    Noah
    Call Box Training.
    Featuring the Panasonic GH2 and Panasonic AC160/130.
  • Peter Groom
    March 29, 2013 at 9:24 pm
    What do your ears tell you?
    It it muffled – increase HFCs or mid
    Is it thin- increase lf
    Is it fluctuating- compress it
    Your ears ave to be the first point if start. What do they say
    Peter
    Post Production Dubbing Mixer
