Activity Forums Apple Final Cut Pro Legacy final cut 5 will not install on Mac 10.4.2 with QT 7
  • final cut 5 will not install on Mac 10.4.2 with QT 7
    Posted by Kari on August 23, 2005 at 12:06 pm
    I was working in a FCP 5 project on my laptop when my laptop died. So, being on a tight deadline, I tried to reinstall FCP 5 on a different computer so I could pick up where I left off and edit through the night. When I tried to reinstall, the FCP part of the installer disk was gray and only CinemaTools. LiveType, etc were available for installation. The computer where I am trying to reinstall, is a new iMac 2GHz PowerPCG5 with 2GB ram. The computer’s other apps were migrated from a different computer after installing the O.S. One of those migrated apps was Final Cut Xpress. I called Apple Care and they told me to do an archive reinstall because it seemed that because Final Cut Xpress was a migrated application it was damaged and was interefering with the installation of FCP 5. I did this and no luck. I threw away everything that had FCP in its name from the computer and I tried again. Made a new user. No luck. I really do not want to have to wipe out my harddrive. Do you have any suggestions? I do not totally understand why migrated software would mess up a new installation..
    Kari
    Phillip Van west replied 21 years ago 2 Members · 1 Reply
  • Phillip Van west
    August 23, 2005 at 1:09 pm
    There are instructions for uninstalling Final Cut Pro 4 at https://docs.info.apple.com/article.html?artnum=301182 . Whether this gets all the FCP 5 files, I don’t know, but there are definitely files you need to delete that don’t have the string “Final Cut Pro” in them…might give it a try. Hope it helps.
    pvw
    Phil Van West
    Terra Nova Productions LLC
    Denver, CO
    Video Production/Post-Production
    G5 DP 2.5GHz / 4.5 GB RAM / 2x250GB SATA / OS 10.4.2 / FCP 5.0.2 / QT 7.0.1
