Activity › Forums › Apple Final Cut Pro Legacy › final cut 5 is all bad i have a dead line and need help
  • final cut 5 is all bad i have a dead line and need help
    Posted by Shaun Wilson on June 10, 2005 at 5:07 am
    I just upgraded to final cut 5 and opend a project up and it all has lines through it they look like ridgies on the edge of all objects.Fast motion is real choppy and some of the new clips that i am trying to drop in are squeezed in from the side some old transisions look choppy also.
    Is there help out there i have been working on final cut since version 3 and media 100 before that I have never had such bad luck upgrading before
    Thanks for your time
    Shaun Wilson
    Shaun Wilson replied 21 years, 3 months ago 6 Members · 7 Replies
  • 7 Replies
  • Steve Wargo
    June 10, 2005 at 6:39 am
    Why in the world would you change software in the middle of a project? Didn’t your mother teach you anything?
    sw
  • Walter Biscardi
    June 10, 2005 at 12:12 pm
    Did you look at the manual and make sure that all of your settings are correct? There are some new user and RT parameters in FCP 5.0.
    Walter Biscardi, Jr.
    Creative Genius, Biscardi Creative Media
    Now in Production, “The Rough Cut,” https://www.theroughcutmovie.com
  • Tom Matthies
    June 10, 2005 at 1:39 pm
    We all “know” that upgrading FCP in the middle of a project is a “no no”. However, there are times it can’t easily be avoided. I have several, on-going clients that do spots each week for air. I usually use the same project for producing the new spots since it has all of the elements that I need. These are price/item type spots. I’ve been doing spots for one of my clients since version 1.25. I do, update the project and clean out outdated materials, but it’s difficult to avoid some overlap when upgrading software or computers. I’d imagine many TV stations that use FCP for daily promos would be in the same boat as well.
    But, so far, so good on my end. I bought a new computer this time around (retiring the trusty old 1Ghz DP) and everything had been installed fresh and squeaky clean. I am, however, about to begin to bring over projects from the old computer. We’ll see how this goes in the next few days. Other than a bad stick of RAM and MANY attempts to get a good replacement, the change over has gone without a hitch.
    Crossing my fingers now…
    Tom
  • Shaun Wilson
    June 10, 2005 at 2:40 pm
    i have all ready played with the motion tab setings and i found the fastest is the best also. yes it is a dv sequence
    i dont know what IO card means dv has never looked so bad i need some help i have also worked with the rt settings and they are all back to what 4 looked like
    Shaun Wilson
  • Mitch Ives
    June 10, 2005 at 3:59 pm
    [Tom Matthies] “But, so far, so good on my end. I bought a new computer this time around (retiring the trusty old 1Ghz DP) and everything had been installed fresh and squeaky clean. I am, however, about to begin to bring over projects from the old computer. We’ll see how this goes in the next few days. Other than a bad stick of RAM and MANY attempts to get a good replacement, the change over has gone without a hitch.
    We have zero problems here on three machines. You were wise to start from scratch. I think Walter already reiterated that recommendation in another post, but whenever there is a new OS, I always start from scratch. It saves time in the end.
    FWIW, we duplicated the same 4.5 project file three times and then converted each of them into FCP 5, using all three methods (normal, best, fastest). We even pasted the clips from the 4.5 sequence into a sequence originating in FCP 5. They all look the same, because in each case, we had it delete the render files when converting.
    A lot of people are reporting diminished video quality and problems with graphics. Remember, Dynamic RT changed things. In our experiment we saw that quality loss occur until we rendered. In the past, we would have had to render first, since we had gamma and color correction filters on the clip, as well as a graphic overlay. With Dynamic RT it will play back with pixelated quality so you can continue trimming without having to stop and render. Once you render, it looks fine. This isn’t a bug, it’s a feature… which you can disable if you want to by switching to High instead of Dynamic. Then it works like the old FCP HD.
    Pilot error will always occur with any technology. If anyone is having issues, I’d wipe the drive and start over from scratch. I installed FCP Studio directly without any old version of FCP even on the drive. Everything is clean and working perfectly (even with beta Io drivers).
    Mitch Ives
    Insight Productions Corp.
    mitch@insightproductions.com
    http://www.insightproductions.com
  • Andy Mees
    June 11, 2005 at 4:14 pm
    Hi Shaun
    not sure if this might be your problem, but you might want to check your field dominance is still correct after the upgrade …. if you’re seeing the chopiness in transitions and other renedred areas (like speed ups) that does sound like the field order has become reversed?
    maybe worth a look
    Andy
  • Shaun Wilson
    June 13, 2005 at 7:47 pm
    i have tryed working with the field domance and that helped but it doesent look like before i am deleteing final 5 and going back to 4.5 thanks all i will wate like i should have before
    Shaun Wilson
