Activity › Forums › Apple Final Cut Pro Legacy › Final Cut 4:3 Clip to 16:9 Sequence
  • Final Cut 4:3 Clip to 16:9 Sequence
    Posted by Amy Lafleche on January 16, 2012 at 11:06 pm
    I was given some footage that is 720 x 480. When I drag and drop it into my sequence it gives me a message that the clip doesn’t match my sequence settings. If I select Yes change settings to match I get a 16:9 sequence but the video stays at 4:3 and if I say No the sequence and clip stay at 4:3.
    The end result that I’m looking for is a 16:9 file for DVD. I export it using Compressor into a mp2 and ac3 file to use in DVD Studio Pro.
    I’ve already cut the timeline together but I’m willing to redo it if there’s a solution.
    Can someone help me sort out the right settings to get this to work?
    Thanks in advance for your help!
    I’ve taken a screen shot (https://amylafleche.com/wp-content/uploads/2012/01/Picture-2.png) and this is what I’m running if that helps:
    I’m running Final Cut Pro 6.0.6
    on
    Mac OS X 10.5.8
    2.66 GHz Quad Core Intel Xeon
    3GB Memory
    Amy Lafleche replied 14 years, 8 months ago 1 Member · 1 Reply
  • Amy Lafleche
    January 16, 2012 at 11:43 pm
    The clip seems to work fine though? Why isn’t it acceptable? Is that why I can’t change the aspect ratio?
    There’s over 12 clips that I’ve used in the timeline so before I convert and recreate I just want to be sure.
    Thanks for your help.
