Activity Forums Adobe After Effects Final Cut 21MB AppleProRes renders 6 times larger in After Effects!
  • Final Cut 21MB AppleProRes renders 6 times larger in After Effects!
    Posted by Kevin Collins on January 20, 2009 at 8:31 am
    I’ve read much about expecting huge files from the AE renders of ProRes/HDV formatted files but six times bigger than the source?
    Is it to be expected that when I import a 21MB Apple ProRes 244(HQ) clip provided by my partner with a Mac and Final Cut into my Windows After Effects that the file size when rendered Animation/lossless with no edits is six times larger than when imported?
    The guy has sent me these clips, into which I have compd some CG elements. Everything’s great until I see the massive file sizes after rendering.
    Am I missing something? Does it even make sense for a FCP user to send Apple ProRes 244(HQ) clips to a Window’s AE guy?
    The details….
    Import footage received from Mac user (shot in HDV 24p 1920×1080) and presumably edited and exported with FCP.
    Format: Apple ProRes 422 (HQ), 1920 x 1080, Millions
    FPS 23.98
    Data size: 20.96MB
    Data rate: 150.63 mbits/sec
    Duration 1.17
    Making no changes, just loading it into AE on my Windows box and the rendering it lossless as follows…
    Quicktime
    Format: Animation, 1920 x 1080, Millions
    Playing and Movie FPS: 23.98
    Data Size: 117.99MB
    Data rate 847.57 mbits/sec
    Duration: 1.17
    Kevin Collins replied 17 years, 7 months ago 2 Members · 3 Replies
  • Kevin Collins
    January 20, 2009 at 6:47 pm
    Thanks Dave.
    I had read your other resoponses on the subject and while I saw plenty indicating that Windows AE Animation compression will definitely create much bigger files from their ProRes422 source, I missed any specific ratios like “6 times larger!”.
    So when I get these files back to my partner using ProRess422, I guess he’ll need to compress with ProRes422 to view these massive data rate files and of course to edit/comp in FCP?
    …all before the final render for his webisode. 🙂
    Do have that right?
  • Scott Roberts
    January 22, 2009 at 9:26 am
    “It’s your choice… but a 140MB file size isn’t bad at all.”
    I agree.
    Color Grading presets for After Effects, Premiere, etc., plus free presets and more.
    LITTLE BLACK BIRD – PROFESSIONAL VISUAL EFFECTS
    https://www.littleblackbird.com
    https://www.myr3d.com
  • Kevin Collins
    January 23, 2009 at 3:15 am
    Thanks Dave and Scott!
    Most helpful to believe I’m not just doing something stupid. 🙂
