Activity Forums Apple Final Cut Pro Fina Cut 10.3.2 Not Auto Filling Gaps
  • Fina Cut 10.3.2 Not Auto Filling Gaps
    Posted by Jake Stevens on August 21, 2017 at 5:18 pm
    Suddenly today, whenever I delete a clip in the timeline, FCPX does NOT auto shift all following clips to the left to fill the gap. I’m forced to select and grab everything after the deleted clip and manually drag everything to the left to rfill the gap.
    How can I fix this, so that FCPX will once again auto shift everything after I delete a clip in the timeline?>????
    iMac 27\”, i7, 4.0GHZ, 5K Retina, 32GB Ram, 512 SDD, 4TB Ext. HD, Final Cut Pro 10.3, After Effects CC v13.8.0.144 – (2015.3 release), Apple Motion 5
    Scott Witthaus replied 9 years ago 3 Members · 3 Replies
  • Oliver Peters
    August 21, 2017 at 7:31 pm
    Are you in the Position mode? Was a slug left in this gap when you deleted the clip? Returning to the default mode (Selection arrow) should get you back to normal.
    – Oliver
    Oliver Peters – oliverpeters.com
  • Oliver Peters
    August 21, 2017 at 7:41 pm
    I just double-checked, so here’s a correction. Both select and position cause the timeline to ripple when you delete a clip. In both cases, holding down shift+delete will leave a slug/gap clip in that space. Is the shift key somehow being held down? If not, try a new Library and see if this behavior is still happening. If it’s still there, then maybe time to delete your preferences.
    https://larryjordan.com/articles/improving-fcp-x-performance/
    – Oliver
  • Scott Witthaus
    August 22, 2017 at 12:05 am
    go to the drop down menu for the cursor tools (just to the right of the edit choice icons) and re-select the top cursor option (select or the A key).
    Scott Witthaus
    Owner, 1708 Inc./Editorial
    Managing Partner, Low Country Creative LLC
    Professor, VCU Brandcenter
