Activity Forums VEGAS Pro Filters/EQ to bring out speech/reduce other frequencies.
  • Filters/EQ to bring out speech/reduce other frequencies.
    Posted by Ben Edwards on August 7, 2010 at 5:19 pm
    Hi everybody,
    I have a interview with background noise, it easy to hear the speech but I was wondering if there was a way to reduce the background noise. The obvious way to do this is apply a EQ where the frequencies for the voice were brought out and other frequencies dropped.
    Is this the way to go and how would I do this?
    What frequency range is the voice at? Or is there another approach I should take?
    Ben
    Ben Edwards replied 16 years, 1 month ago 3 Members · 3 Replies
  • Douglas Spotted eagle
    August 8, 2010 at 3:25 am
    If you don’t have Noise Reduction plugin for Vegas (comes with Sound Forge) then you’re going about it the right way.
    Cut all lows below 100 Hz and that’ll help a lot
    Douglas Spotted Eagle
    VASST
    Certified Sony Vegas Trainer
    Aerial Camera/Instructor
  • John Rofrano
    August 8, 2010 at 2:07 pm
    You also might want to look into purchasing a noise reduction plug-in. As Douglas said Sound Forge comes with Sony Noise Reduction but you could also get BIAS Sound Soap 2 ($89) or iZotope RX ($315). You really should have a noise reduction plug-in in your kit.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Ben Edwards
    August 9, 2010 at 11:11 am
    I would rather use EQ than noise reduction filters (at least initially) as this should bring out the voice without changing it too much. From what I can remember Noise reduction works best if you have a fairly uniform noise like a hum. people walking around etc.
    I did Google for Vegas EQ but just got lots of Vegas Studio related stuff. I will have a play around with the audio filters when I get home.
    Ben
