Activity › Forums › Apple Final Cut Pro Legacy › Filters not applied when I export
  • Filters not applied when I export
    Posted by Chris Schwartzy on November 13, 2012 at 1:25 am
    Hi all!
    I’ve done a number of color correction filters in my sequence (3-way color correct, vignette, etc) and they look fine in my timeline/browser/etc… but then I either render them and then they are not visible anymore (the filters are still applied – but the effects of them are not showing in the rendered clips), or I do an export and the Quicktime looks the same way – like no filters were applied. Is this a setting somewhere that I’m getting wrong?? I feel it’s only doing this on my FCP at work, not on my home computer.
    Thanks for your help!
    Chris Schwartzy replied 13 years, 10 months ago 2 Members · 2 Replies
  • Jerry Wise
    November 13, 2012 at 5:22 pm
    go to sequence settings/render control/ and check to see if you have Render & Playback checked.
  • Chris Schwartzy
    November 16, 2012 at 9:34 pm
    Thanks for replying… I have every possible render control checked, and it’s still not keeping the renders. I’m so confused. Maybe just a glitch with this FCP install?
