Filter or Transition problem
I’m trying to find, or mix together filters or transitions to achieve a look. I’m going from video of a clip being played on a TV screen to that actual clip. I have them synced up, but I need the effect and/or transition to go form the clip on the monitor to just the clip.
I want the effect similar to what I’ve seen on The Matrix, when they’re showing Neo the television monitor of what the real world looks like, and then it zooms in to the monitor, and then the image takes up the whole frame. I want it to look like that camera has zoomed in through the TV, and is now in that world.
I know this sounds amatuer, but I need to do this. Any advice on where I should start? Is there and filters I can download or modify to make it have the moir
