Activity › Forums › Apple Final Cut Pro Legacy › Filter for Removing ‘VHS Generation noise’
  • Filter for Removing ‘VHS Generation noise’
    Posted by Marco D. on January 26, 2006 at 5:05 pm
    Hi all,
    Is there a filter I could use to clean a sequence made of VHS extracts ? There is no big b&w noise, but the image is somewhat noisy and grainy (think 2nd gen). I know I can’t expect to get it perfectly clean, but I’d like to clean a bit of this noise. What filter or combination of filters should I tweak with in order to improve my clips quality ?
    Thanks in advance,
    Marco
    Bob O’brien replied 20 years, 8 months ago 4 Members · 4 Replies
  • Marco D.
    January 26, 2006 at 10:46 pm
    I’m lucky enough, the VHS are all cuts from broadcasters output for a corporate client. So all the original material was professionally shot, nicely lit, etc. However, I’m still stuck with VHS from which I need to edit and cut a DVD. Not ideal, but that’s what I have.
    Anyone please let me know if you know a good way of dealing/improving my image quality before compressing my final cut.
    Thanks in advance,
    Marco
  • John Pale
    January 27, 2006 at 5:53 am
    You can use the noise reduction filter in Compressor while you encode.
  • Mike J.
    January 27, 2006 at 5:50 pm
    Actually… Color Correcting VHS footage will help. The color seperation of R G B gets farther apart from each other as VHS is dubbed. Removing color and adding contrast can make it look better.
    In channels there is a chroma offset / channel offset that I believe can let you adjust the R G B a bit for a clearer merge of the 3 channels.
    The noise is kinda’ always going to be there though.
  • Bob O’brien
    January 28, 2006 at 2:59 pm
    Sometimes blurring the image slightly then sharpening helps to remove noise with acceptable results.
    Bobo
