Filmclips are going crazy, starts repeating frames :-s FCPX->AE
Dear HappyCowers,
I’m doing some fire special effects with After Effects and have this huge problem.
I exported my project from FCPX with fcpxml and with the clipexporter app opened it in After Effects.
I already rotoscoped the entire scene, and now when I export it I see frames repeating themselves, it’s really painful.
When I watched all the clips in AE, I saw that it had nothing to do with the applied effects, but the clips themselves where ‘corrupted?’
Then I looked up the frame rate, and AE says it’s 12,5 fps instead of 25 fps? :-s Maybe it’s because there are clips of 25fps and 50fps in the same composition?
I just don’t want to do all the rotoscoping again from scratch :-s
I looked it up on the internet, but haven’t found anyone with the same problem, I don’t know the technical term for it!Thank you so much, it would be great if anyone has experience with this!
xxx
Susan
