Activity › Forums › Apple Final Cut Pro Legacy › Film transfer onto Betacam – which codec?
  • Film transfer onto Betacam – which codec?
    Posted by Trevor Ward on July 9, 2010 at 7:15 pm
    I’ve got some 13-year old archive raw footage (film transfers from 35mm and 16mm stock) on five Betacam tapes and six BetacamSP tapes. Which codec should I use to capture them? I’m thinking NTSC 8-bit is the way to go. ProRes are smaller files, but isn’t ProRes a less quality codec? Or is it really noticeable? If it’s barely noticeable, then I’ll go for ProRes because it will save in storage space and bandwidth.
    This is a documentary with a mixture of formats: HD, miniDV, miniDV film transfers, BetacamSP, 3/4″, and even some VHS. The final deliverable is a 720p30 program.
    -Trevor Ward
    Jerry Hofmann replied 16 years, 2 months ago 3 Members · 3 Replies
  • Jerry Hofmann
    July 9, 2010 at 8:18 pm
    I’d go prores for sure. HQ for the least amount of compression loss if the source has a lot of detail or fast movement, HQ introduces less compression artifact. More than 4:2:2 from analog beta is a waste of space in most workflows.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski.
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
  • Jeff Coleman
    July 9, 2010 at 8:22 pm
    ProRes is a 10bit codec and should yield better results, especially when processing, than an 8bit codec. The Uncompressed 10bit yields the highest quality, but takes a lot of headroom and storage space.
  • Jerry Hofmann
    July 9, 2010 at 8:34 pm
    One things for sure, any other images you mix with this SD 10 bit material, will look better. Titles, graphics, you name it… gradients really show improvement.
    Jerry
