Activity › Forums › DaVinci Resolve › film scans at legal values?
  • film scans at legal values?
    Posted by Lou Cannizzo on December 11, 2011 at 1:26 am
    Hi all,
    I just recieved some footage that was filmed on 35mm and film scaned to ProresQT.
    The Editor took the footage,edited it and rendered out a Prores 10 bit QT for me to color grade. When I imported it and looked at my RGB Parade, it shows a range from 64-235. I was expecting the data to be full range.
    So,my questions are:
    1. Do I have to ask for another render with extended values?
    2. If I use what I have, will it cause any problems grading?
    3. What should I tell the guy to render it out in ie: prores 444, etc. in order to get full range.
    4. OR is this normal to receive legal values for grading?
    Lou
    Charlie Edison replied 14 years, 9 months ago 3 Members · 2 Replies
  • Robert Houllahan
    December 12, 2011 at 12:37 am
    Was it originally scanned on a machine like an Arriscan to DPX frames and then rendered to Pro-ResHQ? Or was it a video transfer from a telecine to Pro-Res? You are definitely missing allot if it is legal 8-bit video.
    -Rob-
    Robert Houllahan
    Director / Colorist
    Cinelab Inc.
    http://www.cinelab.com
    MAHC-PRO 6-Core 3X GTX285 20Tb SAS Wave Panel Panny 11UK SDI Plasma.
  • Charlie Edison
    December 12, 2011 at 1:25 am
    Sounds like you have LOG scans,
    you should be fine color grading to where ever you push it, bit if you want to see linear from you log,just apply a LOG-LIN lut ..
