Activity Forums Avid Media Composer Film Editing ..Avid Media Composer Vs Avid Dv Xpress Pro With Mojo
  • Film Editing ..Avid Media Composer Vs Avid Dv Xpress Pro With Mojo
    Posted by Harcharan Singh on June 21, 2006 at 9:58 am
    Dear Friends,
    I have a simple query.Avid Xpress pro with MOJO has a Film editing option then why should anyone spend so heavily on a Media Composer.Is there a huge quality difference or there is something else.Your comments will help us in deciding for which system to go for to Edit Film.
    Thks
    Harcharan
    Michael Phillips replied 20 years, 2 months ago 4 Members · 5 Replies
  • Liam Stephens
    June 21, 2006 at 12:55 pm
    I recently worked as an assistant on a feature using XpresPro Mojo it was fairly decent. If u have a low budget i recommend i’m sure others will give u reasons fo using composer. Film Scribe worked perfect with it. It really depends on the editor. The editor i worked under was not oo effected and was able to use his user settings which if i recall unlocked a few small features not available in Mojo. Hope that helps
    cheers
    L
  • Liam Stephens
    June 21, 2006 at 7:32 pm
    “few small features not available in Mojo” I meant Xpress Pro! Not Mojo!
  • Liam Stephens
    June 21, 2006 at 7:34 pm
    Sorry for another post. u can’t capture at 24fps with the Mojo. We had the telecine company log and capture it and put it on a Hard Drive for a bit of extra cash.
  • Dom Silverio
    June 22, 2006 at 3:31 am
    You can capture 24p with Mojo using the analog inputs. You can also capture 24p via firewire – no Mojo needed.
  • Michael Phillips
    June 22, 2006 at 10:55 am
    You can capture 23.976 without a Mojo, you need a Mojo for 24p becuase of the sample rate conversion going on from NTSC sources (23.976/29.97).
    Michael
    anything 24fps
