Activity Forums Avid Media Composer FILM: double system sound
  • FILM: double system sound
    Posted by Naz on June 13, 2005 at 9:18 pm
    if shooting this way, with MOS telecine, and sound on hard disk recorder with TC (BWF files), and manually created database and dailies synced on another system, how to get AUDIO into avid? ale’s coming with audio TC and reel different from videotape id and tc…
    All the best, sorry for my english
    Michael Phillips replied 21 years, 3 months ago 3 Members · 8 Replies
  • 8 Replies
  • Charley King
    June 13, 2005 at 9:31 pm
    The time code for both should be identical, if they shot it properly it should be the same time code synced on both.
    Charlie
  • Naz
    June 13, 2005 at 9:38 pm
    its not.
    telecine has kinda abstract timecode, not connected anyhow with slate timecode. more, nobody works in this country in ntsc, so nobody knows exactly whats going on.
    so – the situation is: Nagra V BWF files with roll and tc, and MOS tape labroll with glued together continious camrolls. sync done on different system… but how to create ale database in that system? what codes should be? is theres a way to include tc for digitizing, and keep original nagra’s metadata?
  • Charley King
    June 13, 2005 at 9:45 pm
    The only thing I can be sure of at this point is. I produced many videos with no time code on the nagra. We relied solely on the slate clacks for syncing. Sometimes missing by a frame or so and just adjusting accordingly. It is time consuming, but you can do it. Even did a few without a good slate to work with. Those were even more time consuming, but after a while you get really good at lip reading.
    Charlie
  • Naz
    June 13, 2005 at 9:53 pm
    many thanks for you, Charlie, but there’s no any problem to get in sync. i do sync on fcp system, then trying to send it to film editor on adrenaline. i cant get a clue how to preserve original timecode, or how to digitise from .ale database in avid. all audio is on the hard drives/dvd’s at moment.
  • Charley King
    June 13, 2005 at 9:56 pm
    Sorry I couldn’t be more help. Maybe next time.
    Charlie
  • Michael Phillips
    June 14, 2005 at 7:31 pm
    Import ALE file for picture capture.
    Drag and Drop BWF files into bin. Timecode will be decoded durting imnport from the files.
    Copy START timecode from BWF files into AuxTC1
    Copy smartslate timecode into AuxTC1 for picture
    AutoSync based on common timecode found in AuxTC1
    You can farther refine sybc on 1/’4 frame basis by using 1/4 frane resync butons found on the tool pallette under EDIT.
    Michael
  • Naz
    June 14, 2005 at 8:02 pm
    thank you very much!
    but… its 24p project, so what happening with pulldown? i mean 23.98 vs 24 when telecine? files are 30 NDF…
  • Michael Phillips
    June 15, 2005 at 11:09 am
    That’s whay you work in a 24p project and not 23.976. SInce the original shooting rate and recording rate were 24fps with 48kHz, this project type preserves that relationship regardless of telecine tapes being 23.976. When capturing 23.976 in a 24fps project, the playback speed is automatically returned to 24fps to be in sync with original production audio.
    see my article on project types for the Motion Picture Editor’s Guild:
    https://www.editorsguild.com/newsletter/MayJun04/mayjun04_23-24_proj.htm
    Michael
