Activity Forums Adobe Premiere Pro Film dissolve bug?
  • Film dissolve bug?
    Posted by Tom Slemmons on July 11, 2016 at 5:29 am
    I noticed the following issue recently in a couple of projects. It only happens in exported files, not in the program window.
    When I apply film dissolve to a title, either a PNG file or a title made in premiere using the title maker, AND I adjust the opacity in the effects control panel, the title fades in from 0% opacity to 100& opacity during the film dissolve transition and then jumps back down to the opacity that I have adjusted it to in the effects control panel. So what you end up with is a title the fades in to 100% and then jumps abruptly down.
    Any idea what Premiere does this? If I change the opacity of the text before I export it to a PNG file, I’m using InDesign to make my titles, then there isn’t an issue. Alternatively if I change the opacity in the title maker window in Premiere then there similarly is no issue. It only happens when I adjust opacity in the effects control panel.
    The issue is also only visible when I export the file. Doesn’t matter what I’m exporting to, all file types show the issue.
    I’m using the following setup:
    iMac (Retina 5K, 27-inch, Late 2015)
    4 GHz Intel Core i7
    32 GB 1867 MHz DDR3
    AMD Radeon R9 M395X 4096 MB
    Premiere Pro CC v9.2.0 (41) Build
    Tom Slemmons replied 10 years, 2 months ago 3 Members · 4 Replies
  • Paul Neumann
    July 11, 2016 at 9:44 pm
    Try nesting the title with the lowered opacity applied then apply the dissolve effect to that.
  • Tom Slemmons
    July 15, 2016 at 6:49 am
    Thanks. After messing around with this for quite a while I decided to just avoid the issue all together by not adjusting the opacity and applying film dissolve. I feel like this is definitely a bug. I guess I’ll try to alert Adobe to the issue.
  • Duke Sweden
    July 15, 2016 at 8:16 am
    Excuse my ignorance but isn’t it easier to just apply the film dissolve? I’m not criticizing your technique, I’m an amateur. I’m just curious why you do it your way.
  • Tom Slemmons
    July 15, 2016 at 9:02 am
    The issue comes up when I need a title to be semi-transparent AND fade in.
    Sorry if my explanation isn’t very clear.
