Activity Forums Boris FX Film Damage Yellow and Blue
  • Film Damage Yellow and Blue
    Posted by Rachel Max on April 20, 2009 at 8:34 pm
    Hi – I’m having an issue many of you have seem to have had but I couldn’t find a solution on the forum. When I apply film damage it is rendering blue and yellow instead of shades of grey and black.
    I’m running BCC 5.0.1 on AE CS4 on a dual 2.66 GHz INtel Xeon with 10 GB of RAM on OS 10.5.6.
    Any help appreciated.
    Rachel
    Peter Mcauley replied 17 years, 5 months ago 2 Members · 1 Reply
  • Peter Mcauley
    April 24, 2009 at 8:45 pm
    The issue that you are seeing is related to the read order of RGBA date in MacIntel equipped systems. There is code that is internal to the filter that was expecting the byte order to read RGBA but we are being told that it is ARGB by the system, hence the color swap that you are seeing . This issue has been fixed with BCC 6.
    I suggest that you upgrade BCC 5 to BCC 6 to take advantage of the fix for this issue, and if you upgrade you’ll also gain an additional 15 amazing new filters as well as many other new features such as animated presets, faster filter renders due to enhanced multi-processor code and more. You can read about it here:
    https://www.borisfx.com/after_effects/bccae/
    Cheers,
    Peter.
