Activity Forums Apple Final Cut Pro Legacy Film burn / Light Leak problem (Video link included)
  • Film burn / Light Leak problem (Video link included)
    Posted by Jim Elliott on March 16, 2012 at 1:40 pm
    Having some trouble adding light leaks in this sequence in final cut. I put several light leaks over the sequence but at the point of the leak clip starting (the leaks are set to ‘screen’ composite mode) the blacks seem to get darker. This is not a problem I’ve had before with other light leeks :s
    https://www.youtube.com/watch?v=045sF2U3l6A – have a look at this to see the problem
    Jim Elliott replied 14 years, 5 months ago 1 Member · 1 Reply
  • Jim Elliott
    March 16, 2012 at 2:31 pm
    Have also noticed that when i move the leak clip to a different track, it look fine BEFORE render (no colour change), but the colour/contrast change comes back again after render 🙁
