Activity › Forums › Adobe After Effects › Filling space between animated paths
  • Eric Santiago
    February 16, 2023 at 4:08 pm
    Hmm, convenient not sure.
    I would render out a version with a solid color bg then re-import and use Roto.
    You can still use the original path animation and use it as top layer.
  • Filip Vandueren
    February 17, 2023 at 12:34 pm
    I’ve never in 20 years used it but: the effect Generate -> Paint Bucket can do this, if you don’t mind that the fill isn’t vectorial but a pixeleffect.
