Activity › Forums › Adobe Illustrator › Filling gaps between objects
  • Filling gaps between objects
    Posted by Steve Sweet on June 8, 2015 at 2:16 pm
    Excuse me if this is a stupidly simple question but how can I join a number of objects with gaps between them together? Filling the gaps essentially.
    I have this from a client
    Each segment of the rope is a different object. I want to create a solid version without the gaps between so that I have one solid path I can take into After Effects as a mask.
    Thank you.
    Vincent Rosati replied 11 years, 3 months ago 2 Members · 1 Reply
  • Vincent Rosati
    June 10, 2015 at 3:32 pm
    Could you draw a path on top of the rope, then set the weight to achieve the desired thickness.
    Vince
    *Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
